Using wildcards with classes
The redirection portion works perfectly. The problem is that the name portion has a lot of wildcard URIs and I can't figure out how to deal with them.
I'm posting a portion of a test data set, the current iRule, and the class commands from the config. I would really appreciate any help I can get.
testdatagroup_file
"/A1/" := "http://192.168.201.250/a.html",
"/A1/*" := "http://192.168.201.250/Athens/a.html",
"/B1/" := "http://192.168.201.250/b.html",
"/B1/*" := "http://192.168.201.250/Boston/b.html",
"/C1/" := "http://192.168.201.250/c.html",
"/C1/*" := "http://192.168.201.250/Chicago/c.html",
"/D1/" := "http://192.168.201.250/d.html",
"/D1/*" := "http://192.168.201.250/Dallas/d.html",
"/E1/" := "http://192.168.201.250/e.html",
"/E1/*" := "http://192.168.201.250/Elvira/e.html",
"/F1/" := "http://192.168.201.250/f.html",
"/F1/*" := "http://192.168.201.250/Franklin/f.html",
"/g/" := "http://192.168.201.250/g.html",
"/g/*" := "http://192.168.201.250/Gulf/g.html",
"/h/" := "http://192.168.201.250/h.html
"/h/*" := "http://192.168.201.250/Hanover/h.html
"/i/" := "http://192.168.201.250/i.html
"/i/*" := "http://192.168.201.250/indigo/i.html
class testdatagroup {
type string
filename "/config/testdatagroup_file"
separator ":="
redirectirule
Set debug to non-zero in the events you want to debug
debug levels: 0 - warnings only, 1 - testing, 2 - verbose
WARNING: verbose logging will be enormous with production dataset
set debug 2
Set data variables
set HTTP_URI [HTTP::uri]
set HTTP_HOST [HTTP::host]
foreach element testdatagroup {
if {[string match -nocase $element $HTTP_URI]}{
log local0.notice "Element $element"
break
if { $debug > 0 } {log local0.notice "HTTP_URI set to [HTTP::uri] and HTTP_HOST set to [HTTP::host]."}
HTTP Redirect if correct
if { [string tolower ${HTTP_URI}] starts_with "/search?" and [URI::query ${HTTP_URI}] != ""} {
set my_query [URI::query ${HTTP_URI}]
if {$debug > 0} {log local0. "Redirecting ${HTTP_URI} to http://[HTTP::host]/Search/?${my_query}"}
HTTP::redirect "http://[HTTP::host]/Search/?${my_query}"
return
when HTTP_RESPONSE {
set dgname "testdatagroup"
if { $debug > 0 } {log local0.notice "Data Group: $dgname"}
log local0.notice "URIPATH [URI::path $HTTP_URI]"
set DG_name [class search -name testdatagroup contains $HTTP_URI ]
log local0.notice "DG_name: $DG_name"
if { [string match "\*" "${DG_name}"]} {
set name [class match -name $HTTP_URI starts_with testdatagroup ]
set value [class match -value $HTTP_URI contains testdatagroup]
if { $debug > 0 } {log local0.notice "Name Value: $name"}
set newmap [class search -value testdatagroup equals [class match -name $HTTP_URI starts_with testdatagroup ]]
if { $debug > 0 } {log local0.notice "Redirect: $newmap"}
HTTP::respond 301 Location "$newmap"
Once again, I would appreciate any help at all.
Cosby
- hoolio
Hi Cosby,
I'd break up the datagroup into one that has all of the "equals" matches (/A1/, /B1/, etc) and another that has the "starts_with" matches (/A1/*, /B1/*, etc entered in the datagroup as /A1/, /B1/, etc). You can then use [class match -element [HTTP::path] equals uris_datagroup] and [class match -element [HTTP::path] starts_with uris_datagroup].
Aaron - Cosby_17532
Aaron,
Thank you for your reply. I'm not sure I made myself clear. The data set has wildcards in it because the users may enter almost anything in. For example, the user may enter www.corpwebsite.com/petfriendsshop/en_US/doggiebites/123456/catalog.pdf. In the data set we may have the following entries:
"/petfriendsshop/" := www.corpwebsite.com/petfriendsshop/intl/dogfood/123456/catalog.pdf
"/petfriendsshop/en_US*" := www.corpwebsite.com/petfriendsshop/en_US/dogfood/123456/catalog.pdf
The second entry is a wild card entry, no matter what is entered by the customer it should redirect them properly. As long as the URI starts with /petfriendsshop/en_US/.
Cosby - hoolio
Yep, so for any exact match like /petfriendshhop/, you'd add it to the exact match datagroup and use the equals operator. For a URI token that has a * on the end, you'd add it without the * to a "starts_with" datagroup and use the "starts_with" operator on class match. Similarly, if you had ends_with checks you wanted to do, you could use the same logic as starts_with. If you need to support wildcards in the middle of strings in the datagroup, you'd need to retrieve the entire datagroup as a TCL list using 'class get' and then loop through the entries one by one using 'string match'.
Aaron - Naman_65674
Hi Hoolio,
Has there been any developments in the later versions of v10 or v11 that support exact and wildcard URLs in the same datagroup? We would like to use class match to do this but conscious of its limitations. - webops_97953
+1 this feature would be great! and also supporting wildcards when creating data-groups with tmsh
- Arie
Altostratus
You can work around the limitation by moving the match indicator (wildcard vs. exact match) to the value and using a separator.
In other words,
becomes
"/g/" := "*;http://192.168.201.250/Gulf/g.html"
and
becomes
"/E1/" := "=;http://192.168.201.250/e.html"
This way you can build logic into your code to handle the two scenarios. I can elaborate if necessary.
- webops_97953
nice workaround, thanks you!
