Humair_167681's avatar
Humair_167681
Aug 21, 2015
Solved
using VIP to connect to Active LTM
Hi all,
We have two LTMs in a HA pair. When we connect to one of the devices, sometimes we find that it is not the Active device and then we have to log onto the other device.
Therefore to solve this problem, I would like to find out if there is a way we can configure a VIP on the LTM so that we also connect to the Active device and not the Standby device?
  • If your security allows it you could add a DNS entry pointing to the floating IP of one of your traffic interfaces and then configure it to allow access to the management interface that way. We do that for our LAN based F5's and it works really well for our support teams.
