Using the Model Context Protocol with Open WebUI
This year we started building out a series of hands-on labs you can do on your own in our AI Step-by-Step repo on GitHub. In my latest lab, I walk you through setting up a Model Context Protocol (MCP) server and the mcpo proxy to allow you to use MCP tools in a locally-hosted Open WebUI + Ollama environment. The steps are well-covered there, but I wanted to highlight what you learn in the lab.
What is MCP and why does it matter?
MCP is a JSON-based open standard from Anthropic that (shockingly!) is only about 13 months old now. It allows AI assistants to securely connect to external data sources and tools through a unified interface. The key delivery that led to it's rapid adoption is that it solves the fragmentation problem in AI integrations—instead of every AI system needing custom code to connect to each tool or database, MCP provides a single protocol that works across different AI models and data sources.
MCP in the local lab
My first exposure to MCP was using Claude and Docker tools to replicate a video Sebastian_Maniak released showing how to configure a BIG-IP application service.
I wanted to see how F5-agnostic I could be in my prompt and still get a successful result, and it turned out that the only domain-specific language I needed, after it came up with a solution and deployed it, was to specify the load balancing algorithm. Everything else was correct. Kinda blew my mind. I spoke about this experience throughout the year at F5 Academy events and at a solutions days event in Toronto, but more-so, I wanted to see how far I could take this in a local setting away from the pay-to-play tooling offered at that time. This was the genesis for this lab.
Tools
In this lab, you'll use the following tools:
Ollama and Open WebUI are assumed to already be installed, those labs are also in the AI Step-by-Step repo:
Once those are in place, you can clone the repo and deploy in docker or podman, just make sure the containers for open WebUI are in the same network as the repo you're deploying.
Results
The success for getting your Open WebUI inference through the mcpo proxy and the MCP servers (mine is very basic just for test purposes, there are more that you can test or build yourself) depends greatly on your prompting skills and the abilities of the local models you choose. I had varying success with llama3.2:3b. But the goal here isn't production-ready tooling, it's to build and discover and get comfortable in this new world of AI assistants and leveraging them where it makes sense to augment our toolbox.
Drop a comment below if you build this lab and share your successes and failures. Community is the best learning environment.
1 Comment
- acnewberry
Employee
Thank you for posting this. I just tried it and it worked great. This is a good building block for other F5 related MCP projects.
