stolivar_88319's avatar
stolivar_88319
Mar 28, 2012
Using iRule for host header and uri routing (problem)
I have a virtual Server(F5) set up on an IP. I have two websites that share this IP and IIS is configured to handled host header hosting. I also run some java tomcat apps on one of the domains hosted so I need to route that to a different pool as well. So here is my config and maybe you all can help me
Virtaul server: Listens on 10.120.1.30 for www.host1.com, www.host2.com
www.host1.com gets routed to host1 pool
www.host2.com get routed to another pool
www.host1.com/pubservices-war gets hosted to tomcat pool
This all works correctly, but for some reason, I think something is being stripped out when host1 gets directed to the tomcat pool.
switch [HTTP::host] {
www.host2.com { pool host2 }
www.host1.com {
if { [HTTP::uri] starts_with "/itunesu" } {
pool www.host1-Tomcat
} elseif { [HTTP::uri] starts_with "/iTunesu" } {
} elseif { [HTTP::uri] starts_with "/iTunesU" } {
} elseif { [HTTP::uri] starts_with "/pubservices-war" } {
} elseif { [HTTP::uri] starts_with "/ref_form" } {
} elseif { [HTTP::uri] starts_with "/ccv" } {
I believe by default all traffic goes to the default pool host1 as configured by the virtual server unless configured differently in the iRule.
Any thoughts?
  • hoolio's avatar
    hoolio
    Hi Stolivar,
    Can you try this version of the iRule which explicitly selects a pool for all cases? Once you're done testing, you can disable or remove the debug logging.
    when CLIENT_ACCEPTED {
     Log debug to /var/log/ltm? 1=yes, 0=no.
    set switch_debug 1
     Save the name of the VS default pool before the iRule could change it
    set default_pool [LB::server pool]
    switch [string tolower [HTTP::host]] {
    www.host2.com {
    pool host2
    if {$switch_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Using host2 pool for [HTTP::host][HTTP::uri]"
    return
    www.host1.com {
    switch -glob [string tolower [HTTP::uri]] {
    "/itunesu*" -
    "/pubservices-war*" -
    "/ref_form*" -
    "/ccv*" {
    if {$switch_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Using www.host1-Tomcat pool for [HTTP::host][HTTP::uri]"}
    return
     If we are still in the iRule select the VS default pool
    pool $default_pool
    if {$switch_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Using $default_pool pool for [HTTP::host][HTTP::uri]"}
    when LB_SELECTED {
    if {$switch_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Selected [LB::server]"}
    when SERVER_CONNECTED {
    if {$switch_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Connected [IP::server_addr]:[TCP::client_port]"}
    Aaron
  • Thanks Aaron, I put that into play and make the changes to actually reflect our real domain names and pools and I get the following error: Thoughts?
    01070151:3: Rule [idu-virtual-websites-pool] error:
    line 8: [parse error: missing close-brace] [{
    salina.kumc.edu {
    pool idu-virtual-websites
    if {$switch_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Using idu-virtual-websites pool for [HTTP::host][HTTP::uri]"
    return
    www.kumc.edu {
    "/itunesu*" -
    "/ref_form*" -
    "/ccv*" {
    pool www.kumc.edu-Tomcat
    if {$switch_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Using www.kumc.edu-Tomcat pool for [HTTP::host][HTTP::uri]"}
    return
    pool $default_pool
    when LB_SELECTED {
    line 9: [command is not valid in the current scope] [switch [string tolower [HTTP::host]] {
    salina.kumc.edu {
    return
    www.kumc.edu {
    "/itunesu*" -
    "/ref_form*" -
    "/ccv*" {
    return
    pool $default_pool
    line 9: [command is not valid in the current scope] [string tolower [HTTP::host]]
    line 9: [command is not valid in the current scope] [HTTP::host]
