Upgrade issues with HA devices using Device trust
So I upgraded from 11.5.0 to 11.5.0 HF2 due to HeartBleed.
I was running on HD1.3 with 11.5.0. I uploaded the new ISO and installed it on HD1.1 patched HF2 on HD1.1 and made it the active boot location and told it to copy over the config.
The system booted and config was copied over and everything was happy besides the cert that is used didn't exist so I had to blow away the trust (via CLI by editing bigip_base.conf "cm cert /Common/dtca-bundle.crt") between the 2 boxes and rebuild after the fact.
My question is: Is there a clean way to upgrade the system and copy over the cert so the trust doesn't need to be broken and rebuilt? or is that just part of the upgrade process?
- yoni_100721
I don't do upgrades very often I guess reloading the UCS is a clean way of doing this.
Thanks!
- nitass
Employee
i think i did not reset trust domain when upgrading. also, i do see dtca-bundle.crt in ucs file.
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) save sys ucs test.ucs Saving active configuration... /var/local/ucs/test.ucs is saved. [root@ve11a:Active:In Sync] config tar tzvf /var/local/ucs/test.ucs |grep dtca-bundle.crt -rw-r--r-- root/root 1298 2014-04-08 20:26:00 var/tmp/filestore_temp/files_d/Common_d/trust_certificate_d/:Common:dtca-bundle.crt_27099_8
