Trying to create Icontrol to retrieve values similar to show /sys connection
Hi guys,
So I want to create a script to help people that don't have access to the LTM find the information available in the show /sys connection command.
But I'm having some trouble finding the right command in the API docs to get that information.
I use the following to dump all my BIG-IP statistics into a metrics system (in this case, Graphite).
https://github.com/mhite/graphite-collectors https://github.com/mhite/graphite-collectors/blob/master/graphitecollectors/f5.py
- mhite_60883
Cirrocumulus
- Brian_Gibson_30
That's pretty cool stuff. Not what I was looking to do per se in this question but this is something I have been looking to do but with the IStats API, albeit not with much luck. - mhite_60883
Cirrocumulus
Ah! Whoops -- didn't read your question close enough, sorry. You probably want this: https://clouddocs.f5.com/api/icontrol-soap/System__Connections.html - Brian_Gibson_30
Perfect! Thanks so much. Also, I am going to play around with that iControl script. That is really interesting and I hate the SNMP polling stats for VIPs.
