Lee_Wendo's avatar
Lee_Wendo
Jan 13, 2022
total-client-side-conns & total-server-side-conns
Why am I not able to get out for {total-client-side-conns total-server-side-conns} on Version-13.1.0.1 yet I am able to get the output on Version-12.1.0? Is it possible to have Version-13.1.0.1 giving the output?
[root@AIR_F5_LB_LTM2:Active:In Sync] config # tmsh show analytics virtual report view-by virtual measures {total-client-side-conns total-server-side-conns} range now--now-1h
Syntax Error: total-client-side-conns is not a valid measure
[root@AIR_F5_LB_LTM2:Active:In Sync] config # tmsh show sys version
Sys::Version
Main Package
 Product   BIG-IP
 Version   13.1.0.1
 Build    0.0.8
 Edition   Point Release 1
 Date    Mon Dec 11 18:03:30 PST 2017
[root@KE-AIR-F51:Active:In Sync] config # tmsh show analytics virtual report view-by virtual measures {total-client-side-conns total-server-side-conns} range now--now-1h
Analytics query result
Time range: 01/13/2022:12:04 (EAT) ---> 01/13/2022:13:04 (EAT)
name       | total-client-side-conns | total-server-side-conns
/Common/AIR_VS_40 | 29276          | 24
/Common/AIR_VS_42 | 0            | 0
[root@KE-AIR-F51:Active:In Sync] config # tmsh show sys version
Sys::Version
Main Package
 Product   BIG-IP
 Version   12.1.0
 Build    0.0.1434
 Edition   Final
 Date    Wed May 11 11:45:11 PDT 2016
  • Hello Lee,
    I've tried this in my lab running version 13.1.3.6.
    The following values can be used as measures:
    Values:
      avg-client-side-concurrent-conns   max-server-side-concurrent-conns
      avg-server-side-concurrent-conns   requests
      client-side-bits-in                server-side-bits-in
      client-side-bits-out               server-side-bits-out
      client-side-conns                  server-side-conns
      client-side-packets-in             server-side-packets-in
      client-side-packets-out            server-side-packets-out
      hw-syncookies                      syncookies
      hw-syncookies-accepts              syncookies-accepts
      max-client-side-concurrent-conns   syncookies-rejects
    Using client-side-conns and server-side-conns I've had an output pretty similar to yours.
    root@(bigip)(cfg-sync Standalone)(Active)(/Common)(tmos)# show analytics virtual report view-by virtual measures { client-side-conns server-side-conns } range now--now-1h
    Time range: 01/13/2022:13:25 (CET) ---> 01/13/2022:14:25 (CET)
    name            | client-side-conns | server-side-conns
    /Common/vs_Demo-APM-VPN    | 0         | 0
    /Common/vs_Demo-DNS-DMZ      | 0         | 0
    /Common/vs_WAF-Tester    | 0         | 0
    Hope this helps,
    CA
  • Thanks for responding CA,
    Yes, I had seen "client-side-conns and server-side-conns "...... My concern however was whether this gives same output as "total-client-side-conns and total-server-side-conns". Is the logic behind these 2 options the same? See outputs below, there is a huge difference in the output values which makes me wonder if they are calculating the same thing... Is there a way to replicate logic behind "total-client-side-conns and total-server-side-conns" onto Version-13.1.0.1?
    root@(KE-AIR-F51)(cfg-sync In Sync)(Active)(/Common)(tmos)# show analytics virtual report view-by virtual measures {total-client-side-conns total-server-side-conns} range now--now-1h
    Time range: 01/13/2022:19:26 (EAT) ---> 01/13/2022:20:26 (EAT)
    /Common/AIR_VS_40 | 40920          | 36
    root@(KE-AIR-F51)(cfg-sync In Sync)(Active)(/Common)(tmos)# show sys version
    Sys::Version
    Main Package
     Product   BIG-IP
     Version   12.1.0
     Build    0.0.1434
     Edition   Final
    root@(AIR_F5_LB_LTM1)(cfg-sync In Sync)(Active)(/Common)(tmos)# show analytics virtual report view-by virtual measures { client-side-conns server-side-conns } range now--now-1h
    /Common/AIR_VS_1 | 78        | 3
    /Common/AIR_VS_2 | 0         | 0
    root@(AIR_F5_LB_LTM1)(cfg-sync In Sync)(Active)(/Common)(tmos)# show sys version
    Sys::Version
    Main Package
     Product   BIG-IP
     Version   13.1.0.1
     Build    0.0.8
    • CA_Valli's avatar
      CA_Valli
      Icon for MVP rankMVP
      Thinking about it, it's likely that "client/server conns" shows current active connections rather than total.
      I've tried to retrieve the info that would be "total" connection when looking at Module Statistics > Local Traffic in GUI and I wasn't able to with available metrics, as well.
      This info might be somewhere in TCP profiles as well however, but I wasn't able to differenciate it by VS.
  • Okay, noted. Thanks. If there would be a way of adding the "total-client-side-conns and total-server-side-conns" options in Version-13.1.0.1, guess that would work. Maybe a way to add it in the configuration or something of the sort.
