Matt_Breedlove_'s avatar
Matt_Breedlove_
Jun 16, 2014
Solved
String glob match for dash or hyphen
Having a probem matching a dash/hyphen in a glob string match inside a switch
I tried the classic TCL way to do it which seemed to be to have the hyphen be leading or trailing so it is not seen as a range character, but that is not working in 11.x. Also tried escaping the a trailing dash which also did not work. Looking back at the TCL docs maybe the leading/trailing dash only applies to regex and not glob string?
Originally tried this which did not work
 switch -glob [string tolower [getfield [HTTP::host] ":" 1]] {
      "[pid][re2][do-]*tools-config.acme.com" {
         log local0. "[IP::client_addr]~[HTTP::host]:[TCP::local_port clientside]~[HTTP::uri]"
Then i tried this which also did not work
Then I ended up working around the problem with this. So my prefix filter is not as good as intended in this workaround.
      "[pid][re2]*tools-config.acme.com" {
So glob string matching on literal dash/hyphen is still needed. Any ideas?
Thanks Matt
  • I am scratching my head trying to see the difference between the first two examples?
    However this expression should do the trick...
    "[pid][re2][do--]*tools-config.acme.com"
    • Matt_Breedlove_'s avatar
      Matt_Breedlove_
      Thank you Kevin. Yes that worked, doubling the dashes at the end of the line gave me a literal dash : ) It would be great if this information was in the string/glob wiki page
    • Kevin_Davies_40's avatar
      Kevin_Davies_40
      I actually couldn't find this information anywhere myself and I looked. I just guessed. Programatically whenever there is a character that has a special meaning, there must always be a way to negate that special meaning. The two most common are using a backslash in front or using two of them in a row.
