Keivannobakht_3's avatar
Keivannobakht_3
Dec 04, 2017
SSL client verification required
I'm confused about how to implement SSL/TLS for connecting 2 servers so here is my scenario.
Server A Obligations:
the server listens for tcp(non http) traffic on port 443.
it will create a self sign private + public.
it will send manually the public for Server B.
Client verification is required.
Server B obligations:
should establish the connection and keep it open and in case o disconnection should establish the connection again
should create self sign private and public
should send manually the public for Server A.
Client verification is required I should mention that F5 LTM will be between the servers and should offload the burden of Encryption and Decryption for server B
  • im also confused
    server A listens, server B doesnt?
    does server A act like a client more or less? setting up a TCP connection to server B?
    perhaps a little picture with and without the BIG-IP LTM will help.
