DavidWong_10382
May 16, 2011SSL cache does not work
Basically, two SSL virtual servers , SSL cache works on one VS, does not work another VS, SSL profile config is below. the only difference between two SSL profiles is just the cache size. the cache does not work on the profile with default setting. I wonder if anyone had this experience before.
Thanks.
below is the SSL client profile which cache does not work, I did ssldunp, the sessionid in serverhello message is zero, but i do not know why F5 sends zero sessionID.
defaults from clientssl
mode enable
key "i1key"
cert "1.crt"
chain "2crt"
ca file "3.crt"
crl file none
client cert ca none
ciphers "ALL:!ADH:!LOW:!EXP:!SSLv2:!NULL:!MEDIUM:!RC4:HIGH:RSA"
passphrase none
options none
modssl methods disable
cache size 20000
cache timeout 3600
renegotiate period indefinite
renegotiate size indefinite
renegotiate max record delay 10
handshake timeout 60
alert timeout 60
peer cert mode require
authenticate once
authenticate depth 9
unclean shutdown enable
strict resume disable
nonssl disable.
- hoolio
Hi David,
The cache size being set to zero or renegotiate setting set for always are the only obvious reasons I could think of for this. I'd open a case with F5 Support on this to get help troubleshooting the issue.
Aaron
