SNAT objects and changing timeout's via tmsh script
Can you edit the objects in the container all at once instead of going one by one? We have tons of objects spanning across numerous nodes and I would hate to have to edit the timeouts on each and every object one by one. Would take forever. Maybe there is a tmsh script somebody has as a template I can use?
Going to each and every object in the SNAT translation list just to change some TCP/UDP/IDLE timeouts in the GUI is very tedious.
Surely there has to be another way. FYI I am a newbie at scripting. And going through all 1583 pages of the tmsh reference guide is not an option right now.
Thanks in advance.
- nitass
Employee
this might not be the best way. Michael has written the following article on bigpipe. bigpipe is no longer available in 11.x but the concept is still applicable using tmsh.
BIG-IP and Merge File Configuration Changes by Michael Yates
https://devcentral.f5.com/articles/big-ip-and-merge-file-configuration-changes.U2MM01dhcdUe.g.
initial configuration root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm snat-translation all-properties ltm snat-translation 1.1.1.1 { address 1.1.1.1 app-service none arp enabled connection-limit 0 description none enabled inherited-traffic-group true ip-idle-timeout indefinite partition Common tcp-idle-timeout indefinite traffic-group traffic-group-1 udp-idle-timeout indefinite unit 1 } modify by merging root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) load sys config from-terminal merge Enter configuration. Press CTRL-D to submit or CTRL-C to cancel. ltm snat-translation 1.1.1.1 { address 1.1.1.1 app-service none arp enabled connection-limit 0 description none enabled inherited-traffic-group true ip-idle-timeout 300 partition Common tcp-idle-timeout 300 traffic-group traffic-group-1 udp-idle-timeout 60 unit 1 } Loading configuration... root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm snat-translation ltm snat-translation 1.1.1.1 { address 1.1.1.1 ip-idle-timeout 300 tcp-idle-timeout 300 traffic-group traffic-group-1 udp-idle-timeout 60 } - ShannonSeverijn
Nitass,
Thank you for the response and the script syntax. This is what I was looking for however I wanted to change all of the SNAT object time-outs in a batch type job. We have hundreds of SNAT pool objects that need to be changed and I just wondered if there was a way to do them all at once at one time since the timeout values will all be the same on all the objects.
I'm guessing there is a way however it would take someone very fluent in tmsh scripting and F5 to help in this capacity and I don't know if that person will read this request and answer.
But I very much appreciate your response and the sample script you provided.
Thank you very much sincerely.
Shannon
- ShannonSeverijn
Do I need to do anything else after I "CTRL-D" the config edits guys? You know like in cisco with a "wr" or "copy run start" etc??
- nitass
Employee
yes, it is in running configuration. you need "tmsh save sys config" to write it to configuration file.
