SharePoint authentication issue with third party client application
We have users using a third party client application that has the ability to connect to a SharePoint site and save documents from the third part application into a SharePoint library.
At present we are unable to authenticate / connect to SharePoint via F5.
The error in the client application logs says:
"Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'."
The application appears to be trying to authenticate using a SharePoint web service
/_vti_bin/Authentication.asmx and expects an XML response back but instead gets an "text/html" response back. Looks like its attempting to authenticate but cannot and eventually is re-directed to my.logout.php3 page.
GET /my.logout.php3?errorcode=20 HTTP/1.1
Does anyone have any ideas as to how one can overcome this?
- Kevin_Stewart
Employee
It's helpful to first understand how APM initiates an access session. When a user first connects to an APM VIP, APM sends the client an immediate 302 redirect to /my.policy and embeds its session cookie. The (browser) client then follows the redirect to /my.policy which starts the "visual" policy evaluation. When the visual policy is complete, a second 302 redirect is issued to the original URL. So it basically looks like this:
-> HTTP request to /foo <- 302 redirect to /my.policy (and set-cookie) -> HTTP request to /my.policy (with cookie) and starts visual policy <-> ... visual policy processing ... <- 302 redirect to /foo -> HTTP request to /foo (with cookie) and access to the application -> ... subsequent requests contain the cookie and no further policy processing happensThis interaction is perfectly acceptable for the average browser session, but doesn't always work for other clients - clients that either don't support cookies or HTTP redirects. For clients that don't support HTTP redirects, there's a slightly different option called "clientless-mode" which essentially disables all of the redirects and sends the session cookie to the client in the first response from the server. Clientless-mode does place limitations on the types of agents that you can use in the visual policy though, specifically anything that creates a dialog with the user (ex. logon page, message box, etc.).
Since the web service client is trying to talk to /_vti_bin/Authentication.asmx with XML data, it sort of implies that APM can't interfere with the direct client-server communication. If you also need to use this VIP for interactive (browser-based) access, then I'd suggest to look for the User-Agent HTTP header (or any other tell-tale sign of web service client) and
- Enable clientless-mode for these requests
- Send the visual policy down a separate path that does not present interactive agents (ie. logon forms, message boxes).
The next question then becomes, how do web services clients authenticate? Are they literally trying to authenticate to the web service via XML (SOAP)? or can they pass other types of authentication (ie. Kerberos, NTLM, HTTP Basic, etc.)?
- yeahnhayeah_144
Thanks Kevin, yes food for thought. I suspected the re-direct was at least part of the problem after reading this article on dev central. There's a script there that enables "clientless-mode" for certain user-agents. So am testing this at the moment and will look at the visual policy path as well. Thank you for your thorough response.
- stan_piron
Cumulonimbus
Hi, look this link : https://devcentral.f5.com/s/feed/0D51T00006i7Y3mSAE I published an irule which allow both Webdav with clientless mode and "office form based authentication" for microsoft office user-agents. - yeahnhayeah_144
Thank you Stanislas, that's very helpful. - stan_piron
Cumulonimbus
Hi, when using clientless-mode, be sure only the unauthenticated request add the clientless-mode header... When clientless-mode is on, the request buffer is limited to 64K which is too much restrictive for Webdav. that's why clientless mode in on only if session cookie doesn't exist in my irule.
