ringoseagull_77
Nov 11, 2011Setting to prevent users refreshing page with F5 button?
Is there a way of preventing users from using the F5 button to refresh a web page?
I'm using Version 10.1, 2 x 1500's.
- nitass
Employee
insert javascript to html pages using irules
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/1179209/showtab/groupforums/Default.aspx
disabling refresh, f5 on a webpage
http://www.theserverside.com/discussions/thread.tss?thread_id=41154
e.g.[root@ve1023:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.65.152:http ip protocol tcp rules myrule profiles { http {} stream {} tcp {} } } [root@ve1023:Active] config b pool foo list pool foo { members 200.200.200.101:http {} } [root@ve1023:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { STREAM::disable if {[HTTP::version] eq "1.1"} { if { [HTTP::header is_keepalive] } { HTTP::header replace "Connection" "Keep-Alive" } } } when HTTP_RESPONSE { if {[HTTP::header Content-Type] starts_with "text/"} { STREAM::expression "@@@" STREAM::enable } } when STREAM_MATCHED { STREAM::disable } } [root@ve1023:Active] config curl -i http://200.200.200.101 HTTP/1.1 200 OK Date: Fri, 11 Nov 2011 14:57:59 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT ETag: "4183e4-3e-9c564780" Accept-Ranges: bytes Content-Length: 62 Connection: close Content-Type: text/html; charset=UTF-8 This is 101 host. [root@ve1023:Active] config curl -i http://172.28.65.152 HTTP/1.1 200 OK Date: Fri, 11 Nov 2011 14:58:06 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT ETag: "4183e4-3e-9c564780" Accept-Ranges: bytes Connection: close Content-Type: text/html; charset=UTF-8 Transfer-Encoding: chunked This is 101 host. - ringoseagull_77
Thanks nitass - nitass
Employee
sorry it appears HTTP::version 1.0 command is missing.
this is the revised one.[root@ve1023:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { STREAM::disable if {[HTTP::version] eq "1.1"} { if { [HTTP::header is_keepalive] } { HTTP::header replace "Connection" "Keep-Alive" } HTTP::version 1.0 } } when HTTP_RESPONSE { if {[HTTP::header Content-Type] starts_with "text/"} { STREAM::expression "@@@" STREAM::enable } } when STREAM_MATCHED { STREAM::disable } } - hwidjaja_37598
Altostratus
Hi Nitass, - nitass
Employee
Hum,
thanks! i tested and it seemed to be okay, so i thought it might be fine. i moved the script to be inside head tag as follows.[root@ve1023:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { STREAM::disable if {[HTTP::version] eq "1.1"} { if { [HTTP::header is_keepalive] } { HTTP::header replace "Connection" "Keep-Alive" } HTTP::version 1.0 } } when HTTP_RESPONSE { if {[HTTP::header Content-Type] starts_with "text/"} { STREAM::expression "@@@" STREAM::enable } } when STREAM_MATCHED { STREAM::disable } } [root@ve1023:Active] config curl -i http://172.28.65.152 HTTP/1.1 200 OK Date: Fri, 11 Nov 2011 15:24:33 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT ETag: "4183e4-3e-9c564780" Accept-Ranges: bytes Connection: close Content-Type: text/html; charset=UTF-8 This is 101 host. - JRahm
Admin
Nice work! Mind if I write a blog on this one? - nitass
Employee
of course not. :-) - JRahm
Admin
sweet! forthcoming.. - JRahm
Admin
and done. Thanks again!
http://devcentral.f5.com/weblogs/jason/archive/2011/11/16/stop-that-f5-key-from-refreshing-the-page.aspx - ringoseagull_77
Great help, thanks very much!
