Cpet's avatar
Cpet
Jul 29, 2019
Security issue - Oracle Identity System Administration login screen is exposed to public
Hi to all,
I have a cluster with 2 Big-IP VM ver13.1 .A VS has the role to load balanced OAM.I discovered that the Oracle Identity System Administration login screen is exposed to public.I found the solution with the below iRule.I want to allow only two networks (internal and VPN)
My question is if I must create two iRules for that.
set static::drop_notallowed 0
when CLIENT_ACCEPTED {
if {not [IP::addr [IP::client_addr] equals 10.0.0.0/8]} {
                log local0. "[IP::client_addr] does not match 10.0.0.0/8 AND access URI = /restricted-URI/"
set static::drop_notallowed 1
if { [string tolower [HTTP::uri]] starts_with "/restricted-URI" }{
if {$static::drop_notallowed==1}{
drop
  • Hi
    You should be able to put all of the logic into the HTTP_REQUEST event, something like...
    	if { [string tolower [HTTP::uri]] starts_with "/restricted-uri" }{
    		drop
    • Cpet's avatar
      Cpet
      Hi iaine,
      Thanks for your prompt reply.
      So you suggest to use http_request iRule and i will agree.
      I must create 2 iRules regarding to allow 2 networks?
  • Hi
    No, just combine the networks with a logical OR.
    If the number of networks starts to get too unwieldy or you want to edit the networks regularly then you could use a Data Group to do a lookup
    	if { not ( [IP::addr [IP::client_addr] equals 192.168.0.0/16]) || ( [IP::addr [IP::client_addr] equals 10.0.0.0/8])} {
    		drop
    • Cpet's avatar
      Cpet
      Hi ,
      Unfortunately does not work. Still have access from external networks.
      Any ideas???
  • What IP address have the external clients got when they hit the VIP - are you natting them to an internal IP...?
  • Cpet's avatar
    Cpet
    Hi iaine,
    I think the irule does not work due syntax error.
    My portal (URL) is https://blabla.com//sysadmin/faces/signin
    So i wrote the following.Please advise if the bold type (URI) fields are correct.
    if {not [IP::addr [IP::client_addr] equals 10.0.40.0/24]} {
                   log local0. "[IP::client_addr] does not match 10.0.40.0/24 AND access URI = /sysadmin/faces/signin"
    if { [string tolower [HTTP::uri]] starts_with "https://blabla.com/sysadmin/faces/signin" }{
    drop
  • Hi
    You don't need the CLIENT_ACCEPTED event to look for the IP and the HTTP::URI command in the HTTP_REQUEST should start from / rather than include http:// etc.
    So your code would look something like
    if { [string tolower [HTTP::uri]] starts_with "/sysadmin/faces/signin"}{
    		drop
  • Cpet's avatar
    Cpet
    Still not working.
    Where\How can i see the logs regarding this rule???
    I need to find out why .
  • here's a couple of log lines to hopefully help. logs will go to /var/log/ltm or the Local Traffic tab in the Logs section of the GUI
    	log local0. "URI is [HTTP::uri] - IP Address is [IP::client_addr]"
    		log local0. "Dropping the connection from [IP::client_addr]"
    		drop
