Julian_46783's avatar
Julian_46783
Dec 07, 2010
Round Robin load balancing method only selects 2 nodes at once.
All,
I have a load balancer pool with 3 nodes in it (a, b, c) set at ratio 1 and priority group 2.
The load balancing method is round robin, however sometimes it’s only a & b processing data, sometimes b & c, and sometimes a & c. This means that all machines are in fact capable of receiving data; but The problem is we can never get all 3 machines processing data simultaneously - a &b & c
What other configuration may be affecting the actual 'balancing'? or am I just misunderstanding Round Robin?
Thanks in advance for the help.
-jp
  • hoolio's avatar
    hoolio
    Hi Julian,
    I'd guess this is due to persistence or client connection reuse. You can check SOL10430 for other ideas:
    SOL10430: Causes of uneven traffic distribution across BIG-IP pool members
    http://support.f5.com/kb/en-us/solutions/public/10000/400/sol10430.html
    Aaron
