Christopher_Hac's avatar
Christopher_Hac
19 years ago
ReturnURL HTTPS into HTTP --help
Hello
I currently have problem with web page using ReturnURL or redirect page from secure page back into normal page.
The web server has secure login web site with the following paramater:
https://www.abcde.com/login.aspx?ReturnURL=%2fuipriv%2fsport.aspx
but after submitting button or logging in, it keeps coming back to the secure web page; it only works only if I added the "http://www.abcde.com" after ReturnURL as shown below
https://www.abcde.com/login.aspx?ReturnURL=http://www.abcde.com%2fuipriv%2fsport.aspx
Please advise whether there is an option/setting on ip3400 for this or how to insert "http://www.abcde.com" using irule?
Thank you in advance.
Chris
  • You can manipulate the URI with the HTTP::uri command. That in conjunction with the TCL string command should get you going.
      if { [HTTP::uri] contains "ReturnURL=%" } {
        HTTP::uri [string map {"ReturnURL=%" "ReturnURL=http://www.abcde.com%" } [HTTP::uri]]
    What this does is look for the existence of the string "ReturnURL=%" in the HTTP::uri and if it is found, it does a string map replacing "ReturnURL=%" with "ReturnURL=http://www.abcde.com%" and assigns the new value to the HTTP::uri.
    Hope this helps...
    -Joe
