Leigh_Bugbee_10
Jul 09, 2015Removing ip address from SNAT pool - deleting current sessions
We need to remove an ip address from a SNAT pool. Once removed, short of failing over an HA pair, what would be the command to delete current connections associated with the specific SNAT pool ip address we just removed?
- pete_71470
In v11, try this:
tmsh show sys connection ss-client-addr a.b.c.d
If the correct connections are matched then change 'show' to 'delete'.
