Removing HTTP headers within an HTTP::respond
Quick question on how to remove items from the HTTP header while doing an HTTP:respond within an iRule. I currently have the following HTTP:respond.
HTTP::respond 200 content $static::blockpage Cache-Control "private" Content-Type "text/html; charset=utf-8"
The output of the HTTP:respond is as follows:
HTTP/1.0 200 OK Cache-Control: private Content-Type: text/html; charset=utf-8 Server: BigIP Connection: Keep-Alive Content-Length: 6952
I need to be able to remove the server, connection and content-length header information within the request. Any pointers on hos this may be accomplished would be appreciated.
- Amit_Karnik
Have you tried the "noserver" option in the HTTP::respond call ?
- nitass
Employee
what about something like this?
configuration [root@ve11a:Active:In Sync] config tmsh list ltm rule qux ltm rule qux { when RULE_INIT { set static::blockpage "hello world\r\n" set static::len [string length $static::blockpage] } when HTTP_REQUEST { TCP::respond "HTTP/1.0 200 OK\r\nCache-Control: private\r\nContent-Type: text/html; charset=utf-8\r\nContent-Length: ${static::len}\r\n\r\n$static::blockpage" } } test [root@ve11a:Active:In Sync] config curl -i http://172.28.24.10 HTTP/1.0 200 OK Cache-Control: private Content-Type: text/html; charset=utf-8 Content-Length: 13 hello world
