zhaleh
May 31, 2018Redirection and xforwarded-for
Hello
When use redirection http to https,There is no way to see the x-forwardedfor on the web server. Also before redirection it was possible to see the x-forwarded for on the web server.
- youssef1
Cumulonimbus
In https virtual server check that http profile use on it, you have set "Insert X-Forwarded-For" to enabled.
or you can use this irule:
when HTTP_REQUEST { HTTP::header insert X-Forwarded-For [IP::client_addr] }But try firts with HTTP profile.
You confirm that you process interception on your HTTPS VS? in fact you use ssl client with http profile...
Regards
Regards
- zhaleh
Thank you for help me
