tempsuli's avatar
tempsuli
Dec 16, 2020
Solved
Redirect iRule problem
Hello,
I would need to do the following with an iRule. Any ideas are appreciated! Basically I need to know how to retrieve the original host in the request and add it to the end in the redirect.
https://www.abc.com/xxx redirected to -> www.xyz.com/portal/dsds?=https://www.abc.com/xxx
Teemu
  • when HTTP_REQUEST {
    	HTTP::redirect https://www.xyz.com/portal/dsds?=https://[HTTP::host][HTTP::uri]
    	# OR:
    	# HTTP::respond 301 Location https://www.xyz.com/portal/dsds?=https://[HTTP::host][HTTP::uri]
    Also, you can achieve the same with a local traffic policy.
    	# OR:
    • jaikumar_f5's avatar
      jaikumar_f5
      Icon for Noctilucent rankNoctilucent
      Please mark the thread as solution provided if its resolved.
