Jobec_45051
Oct 21, 2011ProxyPass v10.2 for APM - Why EXTERNAL data group?
Can someone explain why the data group for ProxyPass v10.2 has to be an external one? I tried using a simple string data group, and this seems to be working fine.
What are the problems I can run in to when using a string data group instead of a external string data group?
We use an active/standby setup of big ip's so I prefer the normal string data group type as this gets copied over to the standby when doing a config sync. The external file had to be edited on both units which may lead to inconsistencies.
- Michael_Yates
Hi iRuler,
You can use either interchangeably.
If your only concern is to have the External (Local File System) Data Group copied to the standby, then you can use either as well (if you store the Data Group in the default location) since they are captured and transferred as part of the Config Sync Process.
Hope this helps. - Jobec_45051
Thanks Michael, that's a big help, certainly the part about the files in /config that are synchonized :)
As a follow-up question: do you have any idea why the documentation states it has to be an external data group? - Michael_Yates
Configuration Requirements
1) The ProxyPass iRule needs to be applied to an HTTP virtual server or
an HTTPS virtual server with a clientssl profile applied to it.
2) A data group (LTM -> iRules -> Data Groups tab) must be defined with
the name "ProxyPassVIRTUAL" where VIRTUAL is the name of the virtual server
(case-sensitive!). See below for the format of this data group (class).
Note that this currently must be an EXTERNAL data group.
I see what you are saying, but I cannot see any reason why the functionality would require it to be an External Data Group. Can you test it with a Non-External Data Group? - Jobec_45051
As I stated in my original question: it does work when using a normal data group.I was just wondering whether I would bump in to any problems by doing so.But either way, I can confirm that it's working. - hoolio
I don't think there is a technical reason it should require an external datagroup. As of 10.1, internal and external datagropus offer the same functionality in terms of name=value pairing lookups:
http://devcentral.f5.com/wiki/iRules.class.ashx
Internal data groups were not able to make use of the name/value pairing with the := separator until version 10.1. As of 10.1 all classes support the name/value pairing.
Aaron
