mgateau's avatar
mgateau
Dec 13, 2020
Prometheus and basic auth
Dear all
I have setup telemetry streaming so that a remote prometheus server can scrape metrics.
I used this advice to use a guest account for "basic auth" done on prometheus :
https://devcentral.f5.com/s/articles/icontrol-rest-fine-grained-role-based-access-control-30773
Here is the prometheus scrape_configs entry :
- job_name: bigip
 honor_timestamps: true
 scrape_interval: 10s
 scrape_timeout: 10s
 metrics_path: /mgmt/shared/telemetry/pullconsumer/My_Prometheus
 scheme: https
 basic_auth:
   username: prometheus
   password: <secret>
 tls_config:
   ca_file: /etc/ssl/certs/ca.crt
   cert_file: /etc/ssl/certs/prometheus.crt
   key_file: /etc/ssl/certs/prometheus.key
   insecure_skip_verify: false
 static_configs:
 - targets:
   - lb5
My problem is excessive warning messages in the logs :
Dec 13 16:33:37 lb5 warning httpd[13888]: [warn] [client XXXX] AUTHCACHE Error processing cookie 7BA470C4F1E2F722E1685046756D1F1A70621E38 - Cookie user mismatch
The problem is clearly identified (K11140735) but changing pam idle timeout is not a solution as promtheus scrapes every 10s which is too low for an usual webui idle timeout.
I was wondering if there is a fix or other way to do it ?
Using a F5 token is not a solution as prometheus does not seam to support it in its scrape_config section (https://prometheus.io/docs/prometheus/latest/configuration/configuration/#scrape_config).
Thanks for your help ;-))
