Michal06's avatar
Michal06
Apr 17, 2025
Problem with sending BotDefense logs to remote server
I have a question about sending logs to a remote log-management server.
When I want to create a bot defense logging profile, it doesn't offer me a remote server in the config menu, but only a local storage, am I doing something wrong? I'm already using a remote server for ASM..
thank you for any advice
I set the same for ASM and the option is already there - I use it fine
Bot Defense - creating new Logging Profile
..to see that the option to select a defined Remote Publisher location is missing
  • Hey! You're not doing anything wrong bot defense logging uses a different logging profile setup than ASM. Unfortunately, it doesn’t support remote log servers directly like ASM does. You’d need to forward the logs manually from local storage or use something like iRules or external log forwarding tools to get them to your remote server. Bit of a hassle, I know.
    • Michal06's avatar
      Michal06
      Hi printerdriversupport​,
      thank you very much for your advice and ideas for solving the situation using alternative methods.
      I´m going to try to use the mentioned iRules, it looks like a way to win! 👍
      • The recommended and standard F5 way is to create a Log Profile as Daniel mentioned it.
  • So there seems to be a gap in answering this. Before it gets too difficult it should be noted that remote logging for bot only supports Splunk format as a destination.
    Environment
    Not able to set up HSL for Bot Defense
    Log Destinations, Log Publishers, Bot Defense Logging Profile
    HSL for ASM/AdvWAF
    Cause
    Bot Defense only supports the splunk format destination
    K15316506: How to send logs via High Speed Logging to Splunk
    https://my.f5.com/manage/s/article/K15316506
    K09439152: High Speed Logging (HSL) For Bot Defense
    https://my.f5.com/manage/s/article/K09439152
    Type: Specifies the type of log destination. Options are ArcSight, IPFIX (logs of IP traffic that are sent to an LTM pool of IPFIX collectors), Management Port, Remote High-Speed Log, Remote Syslog, and Splunk. (The Splunk format is a predefined format of key value pairs.) A table of settings appears below this field. The settings are customized for the log type.
    The workaround is only if you do not have a Splunk formatted destination. But it will show up.
    And of course you can use log stash to transform the log from Splunk to ELK in this scenario.
