Problems with a rewrite. Please help
Hi, I've been asked to write an irule that will intercept anything with a uri that begins with /upload and remove the /upload.
Also, the rule needs to rewrite the host from whatever it is to be the hostname of the server in the pool that it gets served by and to also have :8080 added to it.
https://images.blah.com/upload/document-delivery/uploadfile
to be rewritten to
http://hostname:8080/document-delivery/uploadfile
So far I have come up with this:
set origuri [HTTP::uri]
if { $origuri starts_with "/upload" } {
HTTP::uri [string range $origuri 7 end]
pool pool1
which I thought would at least remove the /upload part of the URI but it doesn't seem to.
Any help is greatly appreciated.
- hoolio
Hi David,
Here's an example which rewrites the host header value based on the selected server IP address:
https://devcentral.f5.com/wiki/iRules.rewrite_host_header_to_server_name.ashx
You could modify that to change the URI as you need to. In pre-v11, the [HTTP::uri] value is cached within the same event. The actual value sent to the pool is updated though. If you want to log the updated value, you can do this in a later HTTP_REQUEST event:when HTTP_REQUEST { log local0. "[IP::client_addr]:[TCP::client_port]: Original request: [HTTP::host][HTTP::uri]" if { [HTTP::uri] starts_with "/upload" } { HTTP::uri [string range [HTTP::uri] 7 end] pool pool1 } } when HTTP_REQUEST priority 501 { log local0. "[IP::client_addr]:[TCP::client_port]: Current request: [HTTP::host][HTTP::uri]" }
Aaron
