michael_trott_1
Aug 18, 2008problems monitoring http with auth
Hi all,
am trying to monitor a http site that presents auth via a popup. i have confirmed the account i am using works, when i vist via browser all ok.
have completed a tcpdump and found that i am getting back a 401 error, Access Denied.
I've tried curl and get the same responce:
curl -N -u : http://10.49.1.68:80/onyxemployeeportal_windows/powerpage/main_frame.asp
Anyone help out ?
thnx
- hoolio
What authentication type is the application using? If it's basic HTTP authentication, then using http://user:[email protected] should work (or the corresponding -u flag for curl). If it's NTLM, then you'd need to use --ntlm for curl.
If you want to monitor an app that only supports NTLM, it gets more complicated. With a default HTTP monitor, you're able to send a single static request and wait to see if the pool member responds. If that response contains a configurable static string the pool member gets marked up. With NTLM authentication, I think you'd need to send multiple requests to negotiate the authentication header value required to access the application. This page (Click here) indicates there are three request/responses required.
If you really need to authenticate with a monitor to check the app, you might be able to write/find a client which can do this and then reference it with an external monitor.
Else, if you just want to check if the service is up and responding, you could send a standard HTTP request and look for 401 in the response (receive string).
Aaron
