Chip_Hudgins_64
Jun 14, 2005problem with rewrite
I am trying to rewrite a URL and have the following iRule which I believe should work:
set DEBUG 0
if { $FINISHED } {
return
if { $DEBUG } {
log local0. "rewrite dev"
log local0. "[HTTP::host]"
log local0. "[HTTP::path]"
if {[HTTP::path] starts_with "/groups/IR/bin/secure/facsurvey.cgi" } {
log local0. "rewrite fac cgi"
log local0. "pre - [HTTP::path]"
HTTP::path "/groups/cit/bin/secure/facsurvey.cgi"
log local0. "post - [HTTP::path]"
pool gwizdev-pool
set FINISHED 1
return
From the ltm logs, I get the following when I goto the page "/groups/IR/bin/secure/facsurvey.cgi"
Jun 14 17:37:13 tmm tmm[18823]: Rule gwzdev_rewrite : rewrite fac cgi
Jun 14 17:37:13 tmm tmm[18823]: Rule gwzdev_rewrite : pre - /groups/IR/bin/secure/facsurvey.cgi
Jun 14 17:37:13 tmm tmm[18823]: Rule gwzdev_rewrite : post - /groups/IR/bin/secure/facsurvey.cgi
As you can see, the command HTTP::path "/groups/cit/bin/secure/facsurvey.cgi" is not working (or I am doing something wrong).
Is there something wrong with the way I wrote the iRule or is there something wrong with the F5? Any help is appreicated.
Thanks for your help.
Chip
- Chip_Hudgins_64
I figured out the answer. It was something I was doing wrong. Thanks
