jhanington_1353's avatar
jhanington_1353
11 years ago
Problem with config-sync all of a sudden. Cannot create archive as well.
I am getting errors when I try to run config-sync on my two 1600 LTMs. Config sync was working before but all of a sudden I cannot do it anymore.
Primary: 10.10.10.12
Secondary: 10.10.10.13
Floating: 10.10.10.14
Running on Primary. Synchronizing to peer.
Checking configuration on local system and peer system...
Peer's IP address: 10.10.10.13
Synchronizing Master Keys...
Saving active configuration...
/home/admin/20140507-1914: (at /home/admin/20140507-1914) does not exist
/home/admin/20140507-1913: (at /home/admin/20140507-1913) does not exist
Errors during file attribute collection
Operation aborted.
/tmp/configsync.spec: Error creating package
Error running config sync all.
BIGpipe parsing error:
   01110001:3: Error running config sync all
Running on secondary. Synchronizing from peer.
Configsync Mode: Pull
Saving temporary UCS on peer...
OperationFailed exception:
   Primary error  : 16908289
   Secondary error: 0
   Error text     : Error saving configuration
   Error saving temporary UCS on peer.
Peer's IP address: 10.10.10.12
Transport and install failed
Error running config sync pull.
   01110001:3: Error running config sync pull
Running on primary. Creating an archive.
Operation aborted.
WARNING:There are error(s) during saving.
        Not everything was saved.
        Be very careful when using this saved file!
Error during config save.
   01020001:3: The requested operation failed.
What is weird is that files do exist in that folder. Both files have 600 level permissions.
  • Here is what I found on ask.f5.com:
    https://support.f5.com/kb/en-us/solutions/public/8000/500/sol8595.html?sr=38157746
    Does that sound like your issue?
    I hope this helps,
    -=Bhattman=-
  • Experienced the same symptoms when attempting to create an archive (backup) file. In our situation... Issue:
    df showed that /shared was 100% used. Cause: mcpd.out file was 55 GB Root Cause: DISA STIGs suggest setting the mcpd logging level to debug.
    Side Note: Many IA folks believe that the security technical implementation guides are not guidelines but hard requirements. Representatives from both DISA and FSS stated that STIGs are suggestions and are not requirements.
    Temporary Solution: transferred Traffic Groups to alternate F5, then rebooted the F5 experiencing the problem. Note that I've previously tried other methods of resetting the mdpd.out file, only to have each require a reboot. Long-term solution: Option A) create a cron job to perform log rotation function; Option B) revert to default logging level of mcpd
    Please share if you've found differing (and preferably better) permanent solution.
