Techgeeeg_28888
Jan 16, 2012Problem in uploading the hot-fix
Hi everyone,
I have recently upgraded the IOS to 11.1.0 now I was trying to upload the hot-fixes using the GUI but it gives error every time... what is the problem is the hot-fix uploaded in some other way ?????? can any one tell me where may the problem be??
Regards,
- Techgeeeg
so if i install the hot fix for IOS version 11.1.0 on another boot volume that is not a problem at all ????? correct???? the cumulative hot fix appears under the hotfix tab how abt the other updates like OPSWAT and Geoloaction fixes when they are uploaded they dont show up under the hotfix tab it seems like they are getting installed directly ???? are they not going to show up under the Hot fix tab or there is something wrong in my setup and it should appear under the tab of hotfixes once uploaded....??????
