Troy's avatar
Troy
Feb 11, 2026
Pktclass Blob load failed
BIGIP version: 15.1.2.1
We are encountering this error on Viprion C4800; is there anyone encounter the same error from your environment?
sg-bigip-0] crit tmm[18415]: 015e0001:2: pktclass: blob_load failed
Is this related to this bug : Bug ID 709563 ?
  • Hello Troy​
    I'm unfortunately unable to find documentation if that bug is what is causing the specific error, however, I would still like to encourage you to update your device to a supported version. To see any bugs you may be impacted by you can use iHealth Upgrade Advisor and I would also suggest following our Software Support Policy for the most up to date supported versions.
    Thanks for being part of our DevCentral Community!
    Melissa
