Rikardo_77456
May 07, 2011Priority Group not working correctly
Hi, I've only been using the F5 BIG-IP for a few weeks and am trying to get priority groups working for one of our pools. I'm sure i've set it up correctly but connections still keep appearing on the lower priority member when they shouldn't. Connections should only appear when the higher priority member becomes unavailable, if i'm correct?
The pool consists of only 2 members, one with priority group 1, the other with priority group 2. Priority Group Activation is set when there is less than 1 available members, but I am still having the issue described above. Any help would be greatly appreciated.
- hoolio
Hi Rikardo,
Do you see the higher priority pool member being marked down by a monitor when the stats increment for the lower priority member?
Aaron - Rikardo_77456
Hi Aaron, thanks for the reply.
No, both members are available the whole time. Could it be something to do with persistence of another pool crossing over? It's the only explanation I can think of.
How we have it set up is one virtual server that by default sends http traffic through pool1 (this includes 2 members, that have cookie persistence), but have an irule that checks the uri for a specific starting string. If the uri starts with this specific string we send it to pool2 (problem pool, as stated above. This includes the same members as pool1, but instead of load balancing we are trying to use priority groups in an active/passive type setup, so that traffic only ever gets sent to one member at a time). Could it be that because the user has already been through pool1, and has a cookie to persist this, that when they get passed through pool2 they get sent to the same member as in pool1? I don't fully understand the cookie persistence and if this could be the case?
Rikardo - hoolio
What kind of persistence are you using on this virtual server? Do you have the same persistence profile defined on a second virtual server with the same pool member or node defined?
Do you have a OneConnect profile on the virtual server? If so, do you have the same OneConnect profile enabled on another virtual server?
We only have one virtual server, with the standard oneconnect profile. The persistence profile is set to cookie, the standard one. The default pool is set as Pool1. Both pools have the same members, using the same nodes. I guess this is the problem then? Is there a better way for this to work? - hoolio
Can you list the VS, pool and OneConnect configs and reply with the anonymized output? You can use 'b virtual VS_NAME list', 'b pool POOL_NAME list' and 'b profile oneconnect OC_NAME list' to get this.
Thanks, Aaron - Rikardo_77456
I hope this is what you are after:
virtual Web_VS {
snat automap
pool Web_Pool1
fallback persist source_addr
destination 192.168.1.25:http
ip protocol tcp
rules {
Force_HTTPS
InsertXForwardedFor
Cache_Selective
ServerSpecificForwarding
URI_Forwarding
RSS_Forwarding
persist cookie
profiles {
ABC_HTTP_Compression_Caching {}
oneconnect {}
tcp-lan-optimized {
serverside
tcp-wan-optimized {
clientside
pool Web_Pool1 {
lb method member ratio
monitor all ABC_Web_Monitor
members {
192.168.1.20:http {}
192.168.1.23:http {
ratio 3
pool Web_Pool2 {
min active members 1
members {
192.168.1.20:http {
priority 1
192.168.1.23:http {
priority 2
profile oneconnect oneconnect {
source mask 0.0.0.0
max size 10000
max age 86400
max reuse 1000
idle timeout override disable
monitor ABC_Web_Monitor {
defaults from http
send "GET / HTTP/1.1\r\nHost:www.abc.com\r\nConnection: Close\r\n"
rule URI_Forwarding {
if { [HTTP::host] equals "www.abc.com" && [HTTP::uri] starts_with "/abc/" } {
pool Web_Pool2
} - hoolio
That's exactly it. Do you have the default OneConnect profile associated with the another virtual server? If so, I think that's the most likely candidate. You can test this by creating a new OneConnect profile and replacing the default OneConnect profile on this virtual server. If that's not it, can you post the other iRules that are enabled on the virtual server?
We do have another virtual server, but it's completely unrelated and not used by the same users. Web_VS is http, while Web_VS2 is https for a different set of users. Should I have another virtual server setup instead of just redirecting the user to a different pool in irule URI_Forwarding?
Other irules:
rule InsertXForwaredFor {
if {[HTTP::header exists X-Forwarded-For]}{
HTTP::header replace X-Forwarded-For "[HTTP::header X-Forwarded-For], [IP::client_addr]"
HTTP::header insert X-Forwarded-For [IP::client_addr]
rule Cache_Selective {
if { [HTTP::host] equals "static.abc.com" } {
CACHE::enable
CACHE::disable
rule Force_HTTPS {
if { [HTTP::host] equals "www2.abc.com"} {
HTTP::redirect "https://[HTTP::host][HTTP::uri]"
rule RSS_Forwarding {
if { [HTTP::host] equals "www.abc.com" && ( [HTTP::uri] starts_with "/rss1/" || [HTTP::uri] starts_with "/rss2/" ) } {
pool Web_Pool1 member 192.168.1.20 80
rule ServerSpecificForwarding {
if {[HTTP::uri] contains "20.html"} {
} elseif {[HTTP::uri] contains "23.html"} {
pool Web_Pool1 member 192.168.1.23 80
