Joe_Pipitone's avatar
Joe_Pipitone
12 years ago
Portion of iRule not being processed
I have combined multiple iRules into one, however the 2nd portion of the rule is not working. I have confirmed using logging that the URI is being caught, however redirection is not taking place. I believe I may not be nesting switch statements correctly.
I have commented which parts of the script are working, and which section is not. Can anyone point me in the right direction?
    These DO work
   if { ([HTTP::host] equals "olddomain.com") } {
        switch -glob [HTTP::host] {
             "/" { HTTP::redirect "http://newdomain.com" }
             default {  HTTP::redirect "http://newdomain.com[HTTP::uri]" }
    These do NOT work
   switch -glob [string tolower [HTTP::host]] {
      "oldforum.olddomain.com" {
          Check the URI, set to lowercase
         switch [string tolower [HTTP::query]] {
            "TID=" {
               HTTP::redirect "https://newforum.newdomain.com/default.aspx?g=posts&t=[URI::query [HTTP::uri] TID]"
               return
            "FID=" {
               HTTP::redirect "https://newforum.newdomain.com/default.aspx?g=topics&f=[URI::query [HTTP::uri] FID]"
               return
            "C=" {
               HTTP::redirect "https://newforum.newdomain.com/default.aspx?g=forum&c=[URI::query [HTTP::uri] C]"
               return
       These DO work
      "*newdomain.com" - "*olddomain.com" {
            switch -glob [string tolower [HTTP::uri]] {
                "/someuri" {
                    HTTP::redirect "http://newdomain.com/path-to/page.aspx"
                    return
                "/someuri2" {
                    HTTP::redirect "http://http://newdomain.com/path-to/page.aspx"
                    return
