Zuke_254875
Altostratus
Apr 03, 2019Port range iRule
We have a requirement for a wildcard virtual server and to allow access to the application servers on port range between 30000 and 32768.
When I apply the below iRule, I'm unable to reach the servers.
when CLIENT_ACCEPTED {
if { {expr [TCP::client_port] < 30000] or [expr [TCP::client_port] > 32768} } {
reject
I'm getting client resets on the pool members when the iRule is applied.
192.168.20.142.53464 > 10.18.142.64.31090: Flags [S], cksum 0xe5ad (incorrect -> 0x12c3), seq 371331784, win 4380, options [mss 1460,nop,nop,TS val 3830442533 ecr 0,sackOK,eol], length 0 out slot1/tmm0 lis=/Common/applicationname-any-vs
17:47:16.391284 IP (tos 0x0, ttl 62, id 26705, offset 0, flags [DF], proto TCP (6), length 40)
10.18.142.64.31090 > 192.168.20.142.53464: Flags [R.], cksum 0x571b (correct), seq 0, ack 371331785, win 0, length 0 in slot1/tmm0 lis=/Common/applicationname-any-vs
As soon as the iRule is removed, traffic connects successfully.
Hi Zuke,
the
command has a build inmplicit expression. No need for the explicitif
command.[expr]when CLIENT_ACCEPTED { if { ( [TCP::client_port] < 30000 ) or ( [TCP::client_port] > 32768 ) } then { reject } }Just for learning purposes the iRules below will work too. But they are more complex and also slower, since you basically pipe the output of the explicit
command (0 or 1) to the implicit expression of the[expr]
command...ifwhen CLIENT_ACCEPTED { if { [expr { [TCP::client_port] < 30000 }] or [expr { [TCP::client_port] > 32768 }]} then { reject } } when CLIENT_ACCEPTED { if { [expr { ( [TCP::client_port] < 30000 ) or ( [TCP::client_port] > 32768 ) }] } then { reject } }Cheers, Kai
- CharlesCS
Cirrus
In this context,
refers to the ephemeral port that the client system uses to connect to the virtual server. To specify the virtual server's port range, useTCP::client_port
instead. Also, "then" is redundant and may cause an error.TCP::local_portwhen CLIENT_ACCEPTED { if { ( [TCP::local_port] < 30000 ) or ( [TCP::local_port] > 32768 ) } { reject } }
