maadavan's avatar
maadavan
Jun 05, 2023
Solved
SSL Offloading for specific IPs or range of IPs
Current flow is as below
Client -> F5 LTM (SSL Proxying) -> On premise Application Servers (TLS Offloading).
Certificates that do TLS offloading has F5 LTM DNS as CN/SAN.
For a migration of my on premise application stack to cloud, I need to achieve below two cases.
Client -> F5 LTM (SSL offloading for specific client IPs & Reencrypt TLS) -> New Stack cloud Application
I have went through Bypass ssl offloading to certain IPs - DevCentral (f5.com) & SSL Offloading using iRules - DevCentral (f5.com). But not the exact case. Would wanted to confirm with experts here in thr forum please. Can someone kindly shed some light & a small example please?
  • Something like this maybe (where offload_ips is a data-group with ip host and ip/mask as specified)
    when CLIENT_ACCEPTED priority 500 {
        if {[class match -- [IP::client_addr] equals offload_ips]} {
            SSL::enable
            pool new_stack_cloud_application
            SSL::disable
            pool on_premise_applications_servers
  • JRahm, I beg to differ and offer a different solution. Not every problem requires an iRule to be solved. 🙂
    I'd rather create two virtual servers, one with pool_A and SSL Bridging configured and another one with pool_B and SSL Passthroughand make use of K14800: Order of precedence for virtual server matching.
    OrderDestinationSourcePort
    1(host address)(network address)(port)
    2(host address)*(port)
    For the source you can use an Address List as described in this Manual article: Configuring Multiple IP Addresses and Service Ports for a Virtual Server. This would replace the datagroup for matching the source IP address(es).
    KR
    Daniel
            SSL::enable
            SSL::disable
      • JRahm's avatar
        JRahm
        Icon for Admin rankAdmin
        untested...make sure to test in a lab! if you have trouble I might be able to mock up tomorrow.
      KR
      Daniel
      • maadavan's avatar
        maadavan
        Hi Daniel,
        Thanks for additional solution. Will weigh out this approach as well. But here for each phase of migration, when I need to add client IP / Inbound Source IP address, I need to make changes in Virtual Server Config which is bit risky isn't it? With iRules, I would need to edit "offload_ips" data group alone. Something similar to config management.
