munish_64882's avatar
munish_64882
Aug 17, 2012
Pool not working
I am facing an issues with the pool members.
I have two pool members listening on port 80
1. 192.168.2.36 and
2. 192.168.2.37
When pool member 192.168.2.36 was down, I was not able to access the website even when 192.168.2.37 was up. But as soon as 192.168.2.36 came up, the website was accessible.
If I see the pool statictics on my load balancer, it shows ZERO out packets/bits for 192.168.2.37.
Please refere to attachment for statistics.
I don't think that there is any issue in the configuration and if one server works, other should also work.
I have configured it as round robin.
Any ideas, why isn't it working.
  • hoolio's avatar
    hoolio
    Hi Munish,
    That sounds odd. Was the 192.168.2.37 member marked down by a monitor? Do you have persistence configured and was the 192.168.2.36 member not marked down by a monitor?
    Aaron
  • the more wierd thing is that 192.168.2.37 is also up and green. Still Its not passing traffic.
    I see 6.0 M in packets but 0 out packets.
  • can you post the virtual server and pool configuration?
    b virtual (name) list
    b pool (name) list
  • Here are the outputs..
    [root@ULFINPG-LB001:Active] config b virtual list
    virtual WEB_VS {
    pool WEB_POOL
    destination 192.168.2.6:http
    ip protocol tcp
    [root@ULFINPG-LB001:Active] config b pool list
    pool WEB_POOL {
    monitor all http
    members {
    192.168.2.36:http {}
    192.168.2.37:http {}
  • can you try to enable "snat automap" under the WEB_VS virtual?
  • what will SNAT achive at this point?
    It will NAT the traffic behind VIP... If this would have been the issue, other pool memeber should not have worked..
    Anyways.. I can give it a try... I will post the update.
  • do both servers use same default gateway? i suspect they might use different gateway.
  • probably yes.. I cannot be sure as I am not managing these web servers.
    But does default gateway comes in picture?
    May be I m confused between IN packets and OUT packets when we see statistics?
  • But does default gateway comes in picture?i guess it does not work since server responds directly to client i.e. client -> bigip -> server (192.168.2.37) -> client.
    May be I m confused between IN packets and OUT packets when we see statistics?have you seen this one?
    sol9077: Overview of BIG-IP traffic flow
    http://support.f5.com/kb/en-us/solutions/public/9000/000/sol9077.html
    hope this helps.
