Zdenda's avatar
Zdenda
Icon for Cirrus rankCirrus
May 17, 2021
Solved
iRule node selection does not work
we have iRule which is supposed to route traffic to specific IP and nexthop + do SNAT based on values in datagroup.
Problem is that command node seems to not be properly working. LB sends TCP Reset just after receiving TCP SYN.
When I remove node and use pool assigned to VIP it works fine.
when CLIENT_ACCEPTED {
   if {[class match [IP::local_addr] equals my_datagroup]}{
       set values [class match -value [IP::local_addr] equals my_datagroup]
       #node [lindex $values 1]
       # try to set node manually
       node 10.10.10.10 50
       nexthop [lindex $values 2] [lindex $values 3]
       if {[llength $values] > 4 }{
           snatpool [lindex $values 4]
       else {
           snat automap
I enabled logging of TCP RST reason (modify sys db tm.rstcause.log value enable) and got this info:
"Route domain is not reachable (strict mode).
But we have all objects in same partitinon/RD. Might it be that command "node" does not work properly at other than Common partition?
We are running at v 13.
Thanks,
Zdenek
  • Try using route domain ID. e.g. if your node resides in route domain 5
    node 10.10.10.10%5 50
