Emre_27149
14 years agopersistansy and compression
I need to your ideas .We tested the bellow irules and it worked.But after get the production some clients complained session persistent and compression.There is a relationship persistency rule that if cookie is disabled then are used session id for persestancy. We compress all file types except msie 6 and some compressed file types.
Thank you.
persistency rule
if { [HTTP::cookie "BSESSIONID"] ne ""} {
persist uie [string tolower [HTTP::cookie "BSESSIONID"]]
log local0. "deneme"
else {
set bsess [findstr [string tolower [HTTP::path]] "bsessionid=" 11 ""]
if { $bsess != ""} {
persist uie $bsess
log local0. "deneme2"
when HTTP_RESPONSE {
if {[HTTP::cookie "BSESSIONID"] ne ""} {
persist add uie [string tolower [HTTP::cookie "BSESSIONID"]]
log local0. "deneme3"
compression rule
if { [HTTP::header User-Agent] contains "MSIE 6" }
log local0. "Header agent [HTTP::header User-Agent] NOT COMPRESSED"
COMPRESS::disable
event disable all
else
log local0. "Header agent [HTTP::header User-Agent] COMPRESSED"
COMPRESS::enable }
if {[HTTP::header Content-Type] contains "png" ||
[HTTP::header Content-Type] contains "jpg" ||
[HTTP::header Content-Type] contains "jpeg" ||
[HTTP::header Content-Type] contains "exe" ||
[HTTP::header Content-Type] contains "swf" ||
[HTTP::header Content-Type] contains "flw" }
{ log local0. "Header agent [HTTP::header Content-Type] PNG NOT COMPRESSED"
COMPRESS::disable
else
log local0. "Header agent [HTTP::header Content-Type] OTHERS COMPRESSED"
COMPRESS::enable }
- hoolio
If you call 'event disable all' it will prevent any further iRule events from being run for the rest of the connection. That would break any further persistence on the connection.
Can you try this instead:when HTTP_REQUEST { if { [HTTP::header User-Agent] contains "MSIE 6" }{ log local0. "Header agent [HTTP::header User-Agent] NOT COMPRESSED" set disable 1 } else { log local0. "Header agent [HTTP::header User-Agent] COMPRESSED" set disable 0 } } when HTTP_RESPONSE { Exit this event in this iRule if we're disabling compression for IE6 if {$disable==1}{ COMPRESS::disable return } switch -glob [HTTP::header Content-Type] { "*png*" - "*jpg*" - "*jpeg*" - "*exe*" - "*swf*" - "*flw*" { log local0. "Header agent [HTTP::header Content-Type] PNG NOT COMPRESSED" COMPRESS::disable } default { log local0. "Header agent [HTTP::header Content-Type] OTHERS COMPRESSED" COMPRESS::enable } } }
Aaron - Why NOT just use the services profiles to enable compression and specify the extensions it compresses?
Regards,
TRX
