f5guyskenzi's avatar
f5guyskenzi
Jul 05, 2024
Packet based load balancing instead of connection based (default)
Hi everyone,
I have a requirement to load balance iso 8583 echo messages across two servers in a pool. I used a performance Layer 4 virtual server to attempt achieving this because I reckon that is the type of virtual server that could fulfill the requirements of load balancing all the requests across the 2 servers in the pool. However, requests are only being sent to one pool member. I also tried to craft an iRule (see below) to do this, still requests are only sent to one pool member.
when CLIENT_ACCEPTED {
 log local0. "ACCEPTED !!"
 TCP::collect
when CLIENT_DATA {
  log local0. "DATA !!"
  #to get the length of messagein hexadecimal,the length info can be get from the first 2 byte
  binary scan [TCP::payload] H4 len
  log local0. $len
  #convertlentodecimal
  scan $len %x len
  log local0. $len
  #totalmessage length is length + 2
  set len [expr { $len + 2} ]
  if {[TCP::payload length] < $len} {
  TCP::collect [expr {$len - [TCP::payload length]}]
  return
  TCP::release $len
  TCP::notify request
  TCP::collect
when LB_SELECTED {
  log local0. [LB::server]
when SERVER_CONNECTED {
    log local0. "Server Connected !!"
    TCP::collect
when SERVER_DATA {
    log local0. "response: [TCP::payload]"
    TCP::release
    TCP::notify response
    TCP::collect
Has anyone done packet-based load balancing before? Any ideas?
  • It is impossible on an F5 device.
    The F5 device can load balance to only one server.
    If you need to send packets to both servers, you can use a client/server clone pool or a TAP switch.
  • BIG-IP really wants to:
    1- Receive a packet for my MAC
    2- Look at the VLAN and L4 source/dest and match a virtual
    3- Add this flow to the flow table
    4- Try to connect the server-side of the flow or continue the client-handshake, depending on how the proflies are set up
    All of the traffic processing hinges upon what's in the flow table, so there's not really a way to "turn it off".
    However, you can easily reconnect the server-side to a different server using "LB::reselect":
    https://clouddocs.f5.com/api/irules/LB__reselect.html
    You can also reconnect the flowserver-side to a server using the "node" command if you want to disregard all BIG-IP load balancing logic:
    https://clouddocs.f5.com/api/irules/node.html
