OTP generation on F5 and sending to Clickatel for two factor authentication
Hi ,
We are trying to configure the F5 OTP as a two factor authentication with below details Partition used for VPN - 2, SMS Gateway - Clickatell. I have refered document mentioned by Jason Rahm for Clickatell integration with F5. The document is very useful.But we are getting below error in report. "HTTP module: authentication with 'XXXXXXXXX' failed: Curl perform failed: Couldn't connect to server (7)" Where XXXXXXXXX is showing mobile number which is mentioned in AD.
Can someone help me understand the possible reasons for this.
Thanks, Rupesh
- kunjan
Can you test from cmd line using curl to check if you have connectivity issue to SMS gateway server?
- Rupesh_M
Thanks Kunjan, I have already tried curl command and getting SMS , it's working fine.
- kunjan_118660
Cumulonimbus
- Rupesh_M
- kunjan_118660
Cumulonimbus
But do you still have issue when triggered thru APM? If yes, can you do packet capture assuming the SMSgateway is on HTTP?
If you are using Route Domain, it won't work.
May also want to check on "Successful Logon Detection Match Value" is obtained in the response if managed to reach the gateway.- Rupesh_M
Thanks Kunjan, We are using route domain for VPN. Is there any workaround to make OTP SMS successful with route domain no 2 ?
- kunjan
- kunjan_118660
Cumulonimbus
APM will initiate the traffic from the RD0. Are you able to route the traffic to internet thru RD0?
- Rupesh_M
I have tried creating HTTP profile in Common partition that is route domain 0, it didn't work. However in this case if traffic will get initiated with RD0 , then I Need to make reachability and allow access from SIP IP of RD0. I will try this option and update you on this.
- kunjan
- Rupesh_M
- kunjan
It's not about the partition, it about the RD it is in.
The other option is to do a layered approach for RD2. But I think if you can route thru RD0, that will be simpler. Just curious, how does your DNS traffic go currently?
- Rupesh_M
Hi Kunjan, Thanks for your reply. Its working now. SMS are getting delivered using SIP of RD0. It uses RD0 SIP for communication with SMS gateway.
- kunjan_118660
Cumulonimbus
- Rupesh_M
- NN_212657
I have a similar problem with the provider textbelt.com, where the curl command fails this way :
curl: (7) Failed to connect to 2400:cb00:2048:1::681c:146b: Network is unreachable
same from the BIGIP command line.
Someone got a clue ?
