BPetronio_11363
Feb 03, 2011Order PartNumber for 1600 LTM+GTM
Hello all,
I know this could not be the best place to ask for it. Im sorry about that.
Could anyone confirm me if the order PartNumber "F5-BIG-GTM-1600-4G-R" has the LTM Module too ?
My intention is to place a purchase order for a 1600 with a LTM+GTM License Module. Is that correct ?
Best Regards,
BPetronio
- Chris_Miller
Altostratus
I don't believe it would, no. Also, as I recall, 1600s can only run one module, so GTM and LTM couldn't live together on a 1600. You'll want to contact your local reseller/f5 sales team on this. - BPetronio_11363
Thanks for your reply Chris,
In fact, that was the idea that i had before.
But then, i found this Solution,Sol10288, Software and platform support matrix, where its clear it supports. (or not ? )
"http://support.f5.com/content/dam/f5/kb/global/pdfs/12889.pdf"
The issue was the correspondent Part Number for that Dual Product Combo.
Hw-1600
Sw-LTM+GTM
Best Regards,
Bruno Petrónio
