kayiz's avatar
kayiz
Dec 12, 2024
Solved
GTM and LTM iquery issues
Hello experts,
We have are facing iquery connectivity issues between our LTM and GTM. any one please guide to solve the same?
\Kayiz
  • Hello kayiz
    Is it first time configuration or the LTM - GTM connectivity was already there? , if its brocken now, could you please run the bigip_add command from the BIG-IP DNS's command line, to ensure that the DNS sync group receives the updated LTM certificate.
    BR
    Aswin
  • kayiz   Hello,  I was able to  pull  this out using AI and your question. let us know if this helps.
    To address iQuery connectivity issues between your LTM and GTM, you can follow these steps:
    1. Ensure that the devices have different self IP addresses configured to establish an iQuery connection successfully.
    2. 2. Verify that the addresses and translated addresses of the corresponding GTM servers match the new configuration.
    3. Restart the big3d service on the LTM device if the virtual servers are not showing up to resolve any hanging processes.
       By following these steps, you can troubleshoot and potentially resolve the iQuery connectivity issues between your LTM and GTM devices.
    • kayiz's avatar
      kayiz
      Hi Its was LTM device cert issues and now i have connected using bigip_add again.
  • Hello kayiz
    BR
    Aswin
