Not able to add pool-member by name using curl command
Hi, I am not able to add pool member (node) by name using curl command. Node does not exist. However it works fine through GUI. I am using v11.5.1.
curl --insecure -u test:test -H "Content-Type: application/json" -X POST --data '{"name":"NodeTT:http"}' https:///mgmt/tm/ltm/pool/BIGIQPOOL/members
{"code":404,"message":"01020036:3: The requested node (/Common/NodeTT) was not found.","errorStack":[]}
- stan_piron
Cumulonimbus
the command is the following:
curl -k -u admin:admin -X POST -d '{"kind":"tm:ltm:node:nodestate", "name":"MonNode", "address":"1.2.3.4"}' -H "Content-Type: application/json" https://X.X.X.X/mgmt/tm/ltm/node/ - JRahm
Admin
As Stanislas indicates, you need to supply the address field if naming the node, however, as you are adding a pool member and not the node itself here, this curl statement should work for you:
curl -k -u admin:admin -X POST -d '{"name":"NodeTT:80","address":"10.10.10.10"}' -H "Content-Type: application/json" https://x.x.x.x/mgmt/tm/ltm/pool/BIGIQPOOL/members/For my system, I slightly modified for a locally defined pool:
request curl -k -u admin:admin -X POST -d '{"name":"NodeTT:80","address":"10.10.10.10"}' -H "Content-Type: application/json" https://172.16.44.128/mgmt/tm/ltm/pool/testpool/members returned data {"kind":"tm:ltm:pool:members:membersstate","name":"NodeTT:80","fullPath":"NodeTT:80","generation":229,"selfLink":"https://localhost/mgmt/tm/ltm/pool/testpool/members/NodeTT:80?ver=11.6.0"} - vimal1771_20809
@Jason Rahm Yeah, I used the same way and it worked. Thanks...
