joxonu_175315's avatar
joxonu_175315
Sep 28, 2015
Solved
Need help with iRule using iFiles
Hey all,
I have an iRule that calles iFiles for a local maintenance page but only seems to work at the root of the URL.
ex. www.example.com/ -> works, renders html text and graphic. www.example.com/anythingelse/ -> fails, only renders html text and no graphics.
    when HTTP_REQUEST priority 10 {
        switch [HTTP::uri] {
            "/down.jpg" {
                HTTP::respond 200 content [ifile get down.jpg] "Content-Type" "image/png" "Connection" "Close"
                event HTTP_REQUEST disable
            "/poweredby.gif" {
                HTTP::respond 200 content [ifile get poweredby.gif] "Content-Type" "text/css" "Connection" "Close"
            default {
                if { ( [HTTP::uri] starts_with "/"  ) } {
                    HTTP::respond 200 content [ifile get down.html] "Content-Type" "text/html" "Connection" "Close"
  • I'm guessing you are trying to match the file no matter the path. If that's the case you need a glob added to the switch and "*" added to your jpg and gif uris:
        switch -glob [HTTP::uri] {
            "*/down.jpg" {
            "*/poweredby.gif" {
            default {
            "*/down.jpg" {
            "*/poweredby.gif" {
            default {
    • joxonu_175315's avatar
      joxonu_175315
      Thanks for the quick response and solution. Really appreciate it!
      joxonu_175315
      Sorry for the delayed response. Yes it is working as expected with the "glob" match. Thanks again for the timely response and fix!
            "*/down.jpg" {
            "*/poweredby.gif" {
            default {
      joxonu_175315
      joxonu_175315
  • Have you created the iFile as both a sys file and an LTM file ie.
    tmsh create sys file ifile "down_jpg" source-path file:/var/class/down.jpg
    tmsh create ltm ifile "down_jpg" file-name "down_jpg"
    You need to in order to reference it from an iRule. In addition I've always removed '.' from iFile names (but not sure if this has been due to madness on my part or an actual issue).
