Grayson_149410's avatar
Grayson_149410
Jan 22, 2015
Solved
iRule 301 Redirect using Wildcard
We are currently running Sharepoint to host our public website. When the user types in www.company.com the URL gets updated to www.company.com/Pages/Home.aspx. This also applies to all other sites within it like www.company.com/Pages/Marketing (with several other flavors).
What I want is an iRule that will see if the user is going to www.company.com. Then change it to a HTTP respond 301 and to lower all strings. So instead of seeing www.company.com/Marketing.aspx they will get www.company.com/marketing.aspx.
Here is an irule that I have tried and does the 301 part, but it always implies the site is just www.company.com. I want to a /* somehow so that any site it sees, it lowers it and does a 301 redirect. here is my curreny rule.
switch [string tolower [HTTP::host]] {
    "www.company.com" {
        HTTP::respond 301 Location "https://www.company.com[HTTP::uri]"
I want it to see if it is www.company.com and if so anything added past the / when it gets added to the particular link it recognizes it.
  • How about this?
    when HTTP_RESPONSE {
        if {[HTTP::status] == 302}{
            HTTP::respond 301 Location "[string tolower [HTTP::header Location]]"
  • I assume your SharePoint site is issuing the responses with uppercase characters? A redirect may not work for what your are trying to accomplish. Are you just trying to make it so a URLs that show up in the browser are all lower case? If that's the case a stream profile for the response may be the best solution.
  • Yes, but I also want it to do 301 redirect instead of a 302. I tried the iRule you posted before you deleted it, but just cased a huge loop.
  • How about this?
    • Grayson_149410's avatar
      Grayson_149410
      I was wondering what would I need to do to find another http status? Some of the sites use 200 requests and would like to make it and if this or if that.
  • How about this?
      Grayson_149410
