ravi_atc's avatar
ravi_atc
Feb 17, 2022
Need help in creating iRule to deny a specific URL and allow all others.
Hi All,
I am new to F5 devices, no experience in creating iRules at all.
The application is hosted (www.example.com) and the traffic is being load balanced using Virtual Servers.
I have a requirement to block a specific URL/path i.e. https://www.example.com/admin/ for all the incoming requests and allow all other paths on this URL.
This can be done using iRule but i am not sure on the iRule syntax to be used.
Any help would be highly appreciated.
  • Hi ravi_atc , you can try below irule syntax.
    When HTTP_REQUEST { if { ([HTTP::host] eq "www.example.com") and (([string tolower [HTTP::uri]] eq "/admin")) } { reject } }
    You can also achieve it using LTM policy.
    Hope it helps!
    • ravi_atc's avatar
      ravi_atc
      Hi Mayur,
      Thank you for the help, since we are in a production environment, i will recommend the given code to the team, will let you know once it gets implemented.
