Albert__Tase_70
Jan 03, 2007Need help converting form 4 to 9
if (http_host matches_regex "demo.nature.com") {
use pool demo
else if (http_host matches_regex "xml.nature.com" or http_host matches_regex "palgravexml.nature.com") {
use pool Autonomy
else {
discard
- Stay away from regular expressions if you can at all help it. Using the switch statement with file globbing (-glob) or the starts_with/ends_with/contains operators can cover most of the cases where users use regular expressions. In your case you are just doing a straight string compare so regular expressions are way overkill.
Here's an example of your rule using the switch statement.when HTTP_REQUEST { switch -glob [string tolower [HTTP::host]] { "demo.nature.com" { pool demo } "xml.nature.com" - "palgravexml.nature.com" { pool Autonomy } default { discard } } }
-Joe
