tororoy76_17327
Jul 27, 2015need help! block requests when ( /administrator and not philippine ip address and not abc.com.ph)
i dont know if this is correct, but here is my irule
when HTTP_REQUEST { if { (!([HTTP::host] contains "abc.com.ph")) and ([HTTP::uri] starts_with "/administrator") and (!([whereis [IP::client_addr]] contains "Philippines")) } { drop } }
Can you suggest a better way to do it? thanks!
- Samir_Jha_52506
Noctilucent
I don't see any issue in iRule. - tororoy76_17327
I tested it and i can't connect to abc.com.ph/administrator using outside of the philippines connection. Maybe there's an error in my composition?
