theizer_91634
Apr 01, 2009multiple redirects - newb needs help
ok...trying my hand at iRules
we own domain.com and domain.net
I need my rule to redirect the following:
1. http://domain.com to https://www.domain.com
2. http://domain.net to https://www.domain.com
3. http://[anything].domain.net to https://www.domain.com
4. http://[anything not "www"].domain.com to https://www.domain.com
5. http://www.domain.com/[path] to https://www.domain.com/[path]
Here is what I have so far. I know I am missing a lot and would really appreciate any help you guys can give.
if {[HTTP::uri] equals {http://domain.com}} {HTTP::redirect https://www.domain.com
elseif {[HTTP::request] contains "domain.net"} {HTTP::redirect https://www.domain.com
else
{HTTP::redirect https://[HTTP::host][HTTP::uri]}
- dennypayne
Employee
One problem is the domain.com, domain.net, etc is not part of [HTTP::uri], it's the [HTTP::host]. URI is the rest of the URL after the host, so your first check would need to be against [HTTP::host] without the http://.
That said, I think you could just do:when HTTP_REQUEST { if { not [HTTP::host] equals "www.domain.com" }{ HTTP::redirect "https://www.domain.com" } else { HTTP::redirect "https://www.domain.com/[HTTP::uri]" } }
Denny - theizer_91634
Thanks for the reply!
I tried your suggestion, but I think I may have something wrong with syntax as nothing redirects when I apply this rule. The iRule editor says it is valid though.
HTTP::redirect https://[HTTP:host][HTTP::uri]
} - hoolio
Try wrapping the condition you're NOT'ing in parentheses:when HTTP_REQUEST { if { not ([string tolower [HTTP::host]] equals "www.domain.com") }{ HTTP::redirect https://www.domain.com } else { HTTP::redirect "https://[HTTP:host][HTTP::uri]" } }
Or this way:when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "www.domain.com" }{ HTTP::redirect https://[HTTP:host][HTTP::uri] } else { HTTP::redirect "https://www.domain.com" } }
Also, because of a bug in the iRule parser in pre-v10 versions, make sure to always wrap // in double quotes. See SOL7988 for details:
SOL7988: The iRule parser may fail to correctly parse and load an iRule from the command line (Click here)
Aaron
