Monitoring poolmember thru html return code
We like to change the way the loadbalancers monitor the poolmembers. Currently, the LB check if a specific port is available/accessible. To give us some flexibility to exclude a poolmember temporarily, we want the LB to check an URL and verify the html return code.
I will give an example. The LB should: •check an URL something like ; •verify the html return code is ‘200’; •use the response time to determine which poolmember is the fastest.
May I ask if this is possible?
- Dan_Pacheco
Cirrus
You are describing two separate features. First is a “http health monitor” to send an http request and receive a http status code back. Secondly distribution method “response time”.
There are several knowledge base articles that describe how to set up health checks in detail. https://support.f5.com/csp/article/K2167
If you still have questions after reading this post back.
- Dan_Pacheco
Cirrus
Also don’t forget to use the full http hostname, not just the short name that you have in your example above.
- markymark_30996
Ok, how about using the response time to determine which poolmember is the fastest? Do we have this kind of feature in F5?
- stan_piron
Cumulonimbus
To check if response code is 200 for URL use following configuration
send string
GET /alive/1.0/alive HTTP/1.1\r\nHost: rbcdevesh210:8081\r\nConnection: Close\r\n\r\nand in receive string
HTTP/1.[01] 200to load balance with priority based on response speed, use fastest(member) load balancing method
