Universal Persistence w. AS3 vs. SCF - the same but not the same
Hi community,
I have an odd issue. When I create the following config manually or with SCF the Universal Persistence works. I get records in the persistence table.
root@(ltm-apm)(cfg-sync Standalone)(Active)(/Common)(tmos)# show ltm persistence persist-records
Sys::Persistent Connections
universal 12345abcde 10.100.155.182:80 10.100.153.127:80 (tmm: 1)
universal 12345abcde 10.100.155.182:80 10.100.153.127:80 (tmm: 0)
This is the config as SCF (at least the relevant parts of it):
ltm virtual vs_persistence_test {
destination 10.100.155.182:http
ip-protocol tcp
mask 255.255.255.255
persist {
uie_jsessionid {
default yes
pool pl_persistence_test
profiles {
f5-tcp-progressive { }
http { }
serverssl-use-sni disabled
source 0.0.0.0/0
source-address-translation {
pool snat_pool_internal
type snat
translate-address enabled
translate-port enabled
vs-index 57
ltm persistence universal uie_jsessionid {
app-service none
defaults-from universal
rule rule_uie_jsessionid
timeout 300
ltm rule rule_uie_jsessionid {
when HTTP_RESPONSE {
if { [HTTP::cookie exists "JSESSIONID"] } {
persist add uie [HTTP::cookie "JSESSIONID"]
persist uie [HTTP::cookie "JSESSIONID"]
Do I deploy the same with AS3, it doesn't seem to work. I cannot see any persistence records.
"$schema": "https://raw.githubusercontent.com/F5Networks/f5-appsvcs-extension/main/schema/latest/as3-schema.json",
"class": "AS3",
"action": "deploy",
"declaration": {
"class": "ADC",
"schemaVersion": "3.0.0",
"remark": "Session persistency w JSESSIONID",
"universal_persist_jsessionid": {
"class":"Tenant",
"App01": {
"class": "Application",
"service_http_80": {
"persistenceMethods": [{
"use": "uie_jsessionid"
"pool": "pl_persistence_test",
"translateServerAddress": true,
"translateServerPort": true,
"class": "Service_HTTP",
"profileTCP": {
"bigip": "/Common/f5-tcp-progressive"
"profileHTTP": {
"bigip": "/Common/http"
"virtualAddresses": [
"10.100.155.182"
"virtualPort": 80
"pl_persistence_test": {
"members": [
"servicePort": 80,
"serverAddresses": [
"10.100.153.126",
"10.100.153.127"
"monitors": [
"class": "Pool"
"uie_jsessionid": {
"duration": 300,
"class": "Persist",
"iRule": "persist_irule",
"persistenceMethod": "universal"
"persist_irule": {
"class": "iRule",
"iRule": {
"base64": "d2hlbiBIVFRQX1JFU1BPTlNFIHsKICBpZiB7IFtIVFRQOjpjb29raWUgZXhpc3RzICJKU0VTU0lPTklEIl0gfSB7CiAgICBwZXJzaXN0IGFkZCB1aWUgW0hUVFA6OmNvb2tpZSAiSlNFU1NJT05JRCJdCiAgfQp9CndoZW4gSFRUUF9SRVFVRVNUIHsKICBpZiB7IFtIVFRQOjpjb29raWUgZXhpc3RzICJKU0VTU0lPTklEIl0gfSB7CiAgICBwZXJzaXN0IHVpZSBbSFRUUDo6Y29va2llICJKU0VTU0lPTklEIl0KICB9Cn0="
FYI, I decided to use base64 for the iRule in AS3.
However, if I do a diff of the iRules in plaintext - they are the same.
BIG-IP version: 17.1.2.1
Now my questions are.
- Am I missing something here?
- Did anybody come accross the same issue?
- Why is it not working?
Thanks for your help
Daniel
Never mind, I managed to figure it out on my own.
Option 1: Use the REST API:
daniel@ubuntu-vm:~$ curl -sk -u admin:<password> GET https://172.31.254.240/mgmt/tm/ltm/persistence/persist-records | jq.exe . -M
"kind": "tm:ltm:persistence:persist-records:persist-recordsstats",
"selfLink": "https://localhost/mgmt/tm/ltm/persistence/persist-records?ver=17.1.2.1",
"apiRawValues": {
"apiAnonymous": "Sys::Persistent Connections\nuniversal 12345abcde 10.100.155.182:80 10.100.153.127:80 (tmm: 1)\nuniversal abcde12345 10.100.155.182:80 10.100.153.126:80 (tmm: 0)\nTotal records returned: 2\n"
}Option 2: Don't be me... change to the right partition
root@(bigip)(cfg-sync Standalone)(Active)(/Common)(tmos)# cd /universal_persist_jsessionid/
root@(bigip)(cfg-sync Standalone)(Active)(/universal_persist_jsessionid)(tmos)# show ltm persistence persist-records
Have you checked that irule is applied on Virtual Server correctly?
Have not played a lot with AS3, but shouldn't you apply irule also under "service_http_80"?
for example
"service_http_80": { "persistenceMethods": [{ "use": "uie_jsessionid" } ], "iRules": ["persist_irule"], "pool": "pl_persistence_test", "translateServerAddress": true, "translateServerPort": true, "class": "Service_HTTP", .......... ..........Thanks Injeyan_Kostas, but that is not the issue.
When using Universal Persistence the iRule is applied to the persistence profile, not to the virtual.
I can also see from the statistics that the iRule is executed. No tcl errors in /var/log/ltm either.Hmm, you are totally right. my bad
"apiRawValues": {
Total records returned: 2Hey Daniel_Wolf nice topic! I wonder if you reference an existing uie persistance with "bigip" like you did for the profiles maybe the records will be in the Common partition.
