Perl PoolMember Monitor
Problem this snippet solves:
This sample illustrates how to get and set a monitor association with a pool member.
Code :
#!/usr/bin/perl
# The contents of this file are subject to the iControl Public License
# Version 9.2 (the "License"); you may not use this file except in
# compliance with the License. You may obtain a copy of the License at
# http://www.f5.com/.
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
# the License for the specific language governing rights and limitations
# under the License.
# The Original Code is iControl Code and related documentation
# distributed by F5.
# The Initial Developer of the Original Code is F5 Networks,
# Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2011
# F5 Networks, Inc. All Rights Reserved. iControl (TM) is a registered
# trademark of F5 Networks, Inc.
# Alternatively, the contents of this file may be used under the terms
# of the GNU General Public License (the "GPL"), in which case the
# provisions of GPL are applicable instead of those above. If you wish
# to allow use of your version of this file only under the terms of the
# GPL and not to allow others to use your version of this file under the
# License, indicate your decision by deleting the provisions above and
# replace them with the notice and other provisions required by the GPL.
# If you do not delete the provisions above, a recipient may use your
# version of this file under either the License or the GPL.
use strict;
use warnings;
$ENV{PERL_LWP_SSL_VERIFY_HOSTNAME} = 0;
#use SOAP::Lite + trace => qw(method debug);
use SOAP::Lite;
# Validate Arguments
my $sHost = $ARGV[0];
my $sUID = $ARGV[1];
my $sPWD = $ARGV[2];
my $sPool = $ARGV[3];
my $sMember = $ARGV[4];
my $sMonitor = $ARGV[5];
sub usage()
die ("Usage: PoolMemberMonitor.pl host port uid pwd [pool [member:port [monitor]]]\n");
if ( !defined($sHost) or !defined($sUID) or !defined($sPWD) )
usage();
# Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials
return "$sUID" => "$sPWD";
# GetInterface
sub GetInterface()
my ($name) = (@_);
my $Interface = SOAP::Lite
-> uri("urn:iControl:$name")
-> readable(1)
-> proxy("https://$sHost/iControl/iControlPortal.cgi");
# $Interface->set_opt(verify
# Attempt to add auth headers to avoid dual-round trip
eval { $Interface->transport->http_request->header
'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
return $Interface;
my $Pool = &GetInterface("LocalLB/Pool");
my $PoolMember = &GetInterface("LocalLB/PoolMember");
# support for custom enum types
sub SOAP::Deserializer::typecast
my ($self, $value, $name, $attrs, $children, $type) = @_;
my $retval = undef;
if ( defined($type) && "{urn:iControl}Common.EnabledState" eq $type ){
$retval = $value;
return $retval;
# Main logic
if ( !defined($sPool)||$sPool eq '' )
&getPoolList();
elsif ( "" eq $sMember )
&getPoolMembers($sPool);
elsif ( "" eq $sMonitor )
&getPoolMemberMonitors($sPool, $sMember);
else
&setPoolMemberMonitor($sPool, $sMember, $sMonitor);
sub getPoolList()
my $soapResponse = $Pool->get_list();
&checkResponse($soapResponse);
my @pool_list = @{$soapResponse->result};
print "AVAILBLE POOLS\n";
foreach my $pool (@pool_list)
print "$pool\n";
sub getPoolMembers()
my ($pool) = (@_);
my $soapResponse = $Pool->get_member(
SOAP::Data->name(pool_names => [$pool])
my @memberListAofA = @{$soapResponse->result};
# Extract the 1st list for the single pool passed in.
my @memberListA = @{$memberListAofA[0]};
print "POOL '$pool' members\n";
# build parameters for set_session_enabled_state();
foreach my $member_def (@memberListA)
my $address = $member_def->{"address"};
my $port = $member_def->{"port"};
print " ${address}:${port}\n";
sub getPoolMemberMonitors()
my ($pool, $member) = (@_);
my ($addr, $port) = split(/:/, $member, 2);
my $soapResponse = $PoolMember->get_monitor_association(
my @MonitorAssociationAofA = @{$soapResponse->result};
my @MonitorAssociationA = @{$MonitorAssociationAofA[0]};
print "POOL '$pool' monitors\n";
foreach my $MonitorAssociation (@MonitorAssociationA)
my $MonitorIPPort = $MonitorAssociation->{"member"};
my $atype = $MonitorIPPort->{"address_type"};
my $ipport = $MonitorIPPort->{"ipport"};
my $addr = $ipport->{"address"};
my $port = $ipport->{"port"};
my $MonitorRule = $MonitorAssociation->{"monitor_rule"};
my $type = $MonitorRule->{"type"};
my $quorum = $MonitorRule->{"quorum"};
print " ${addr}:${port} - ${atype}\n";
print " Type: ${type}, Quorum: ${quorum}\n";
my @monitor_templates = @{$MonitorRule->{"monitor_templates"}};
foreach my $monitor_template (@monitor_templates)
print " $monitor_template\n";
sub setPoolMemberMonitor()
my ($pool, $member, $monitor) = (@_);
my $IPPortDefinition = {
address => $addr,
port => $port
my $MonitorIP = {
address_type => "ATYPE_EXPLICIT_ADDRESS_EXPLICIT_PORT",
ipport => $IPPortDefinition
my $MonitorRule = {
type => "MONITOR_RULE_TYPE_SINGLE",
quorum => 0,
monitor_templates => [$monitor]
my $MonitorAssociation = {
member => $MonitorIP,
monitor_rule => $MonitorRule
my (@MonitorAssociationA,@MonitorAssociationAofA);
push @MonitorAssociationA, $MonitorAssociation;
push @MonitorAssociationAofA, [@MonitorAssociationA];
my $soapResponse = $PoolMember->set_monitor_association(
SOAP::Data->name(pool_names => [$pool]),
SOAP::Data->name(monitor_associations => [@MonitorAssociationAofA])
&getPoolMemberMonitors($pool, $member);
# checkResponse
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
}Published Mar 07, 2015
Version 1.0CodeCentral_194
Joined May 04, 2019
